Valvebounce
I'm throwing together a low(ish) buck 318. I have the 396 heads,(Lame small port ones) but they've had 1.88, and 1.6 valves fitted to them. I've bought an xe274 cam, and the block is .040 over.
Problem is the inlet manifold. I'd kind of like to keep the small port heads to retain strong velocity, but the LD4B seems a bit thin on the ground. I'm spoilt for choice when it comes to the availabilty of inlets for the larger port heads. But that means porting the heads, and I don't want to kill the bottom end responce too much. Plus my budget doesn't extend to a stall converter (yet) so I'd hate for it to be a pig of the line. I have a pair of 28X10.5X15's and I have a 4.08:1 rear end. (If that makes any difference?) I was also planning to deck the block to get the comp up to 10.5:1.
So do I hang out till til I find an LD4B, or just bite the bullet buy a later manifold and port the heads out?
