Which Master Cylinder Relocation block is needed?
MonkeyMadness
Yorba Linda California
I have an early A-body 1965 Barracuda and have a CPP Master Cylinder w/7"booster and it is a bit close to my Valve cover. I would like to shift my booster over a bit but I don't know which relocation kit/block to use for the early A'
I haven’t see 1 for a booster relocate. U may be able to have 1 fabbed up. These pics is for the master cyl. Kim
I only have one question. Why vacuum Power Brakes?
The gold one looks to be the right one for the older iron master cylinder. It has the 4 holes for the studs for the master .It may work with a booster.
The black one looks to be for the light weight aluminum style manual master cyl. with two studs.
U r correct Steve. Kim
Who makes that gold one?
I've been looking and I keep finding the same block says for "68 A-body only" through jeggs, summit, and Manicini
I need it to fit the 65-66 A-body!?! ugh
Idk, I don’t have the original box. I’ll see if I can find anything as I’m pretty sure it has the nuts and bolts with it. Does it look like it will work 4 u? Maybe try in the BO29/LO23 thread. Kim
I does look like it may work.
Whats this: "BO29/LO23 thread" ??
