I work at a shop, and I can't buy Moog parts as cheap as they are on Amazon. I priced my entire front end - ball joints, tie rods, idler, pitman, control arm bushings, etc. It was around $280. That is what I am going with.
That sounds like an excellent idea, never thought of checking amazon. Thanks for the tip man.
On a side note, here is what I have written down for replacement, is there anything I'm not thinking of that should be replaced?
Upper ball joints
Lower ball joints
Upper / lower control arm bushings
End links
End link bushings
idler arm
outer tie rods
inner tie rods
tie rod sleeves
strut rod bushings
upper cam bolts
upper / lower control arm bumpers
pitman arm
torsion bar (1.03")
torsion bar seals and dust boots
torsion bar adjusters
torsion bar clips
power steering gearbox
power steering pump
calipers
pads
rotors
front tires
shocks
I think that just about does it for the front end. I think my plan of action, as of right now is to start ordering parts. Once I stockpile all the parts I need, and I find myself a 360 to rebuild, I'll get started on that. This winter (or next spring, depending on time and money) my brother and I are planning on swapping the engine. When that happens, I'll replace all of the front end parts, and inspect the K-frame at that time. Any and all advice, or parts that I should replace that aren't listed,
OR parts that I have listed that I may not
NEED to replace, to help cut down on cost, will be greatly appreciated.
