which Pertronix module?
Rapid Robert
Lincoln Nebraska
360 2bbl 9-1CR circle track. races may last 15-30 minutes. I purchased a pertronix Ecoil #60103 with 0.32 ohms. which (HEI type) module should I purchase? Their D72000 module is a multispark unit & their D2070 race unit is not. which would you recommend? thank you for your time. RR
You should probably ask Pertronix. We would just be guessing.
Email from them said to use D72000 (multispark) & the strange character I spoke with on the phone said D2070 race module. My Pertronix E coil is 0.32ohms
Get them to confirm that which ever module you are ordering will work with the coil you are using. They are not all interchangeable. I’ll never go down that road again.
0.32 ohms is getting low-ish for inductive ign, might have been designed for CD ign.
Their website description should tell you the application.
Ding ding ding I do believe we have a winna. yes I may have the WRONG coil. I will call them again & see develops. thanks guys! RR
