Treblig
I have two sets of adjustable rockers for the 318 stroker I plan to build. I'm not sure which set would be the best to use on this build. I DO NOT plan any high RPMs or drag racing. Just a healthy street motor...NO HIGH LIFT CAM.
Here are some pics. The first 5 pics are the rockers with what look like bronze rocker arms that have been ground down for bigger valve springs, locking nuts (jam nuts) on the adjusters, springs in between the rockers and no banana grooves. The last 5 pics are the other set, they have banana grooves, spacers between the rockers, no jam nuts on the adjusters and what look like steel (cast iron) rocker arms. Also the banana grove set seems to have some wear (slight damage, see pics) on a few of the valve tip surfaces. Not being a Mopar expert I don't know which set is best to use.
I need to sell the extra set for money to buy stroker parts.
thanks for the help!!!
Treblig
Treblig
