72Dart6pack
Harder Better Faster Stronger.
Maybe this will help too? Also put foam rubber between the scoop and the hood before you bolt it on. Word of advise.
Hmmm it looks like the studs on the one I bought are in a different location. Think I might have to wind up just centering and measuring from the back of the hood . . .good idea, I was planning on using 3m two sided tape for alittle cushionMaybe this will help too? Also put foam rubber between the scoop and the hood before you bolt it on. Word of advise.
Sorry - I don't think it will help you as it's an aftermarket AAR fiberglass hood so it's all molded with the 6-pack scoop.Can you post a picture of the inside of your hood?
I just noticed that scoop is for a 73 dart sport. The foam won't do any good in the front with a beaked scoop on a flat hood. But I never used foam on ant of mine.Maybe this will help too? Also put foam rubber between the scoop and the hood before you bolt it on. Word of advise.
Mine is the correct scoop for a 1972 Dart. What other people are doing is no concern of mine. I'm just showing you a example of a 1972I just noticed that scoop is for a 73 dart sport. The foam won't do any good in the front with a beaked scoop on a flat hood. But I never used foam on ant of mine.
Yeah, seems to be what others are saying also, thing is I already purchased that hood and have it on its way. .I thought you were replacing a Sixpack scoop (with an assumed hole cut in it) with something else. PLEASE, don't cut up a nice steel hood! I did that on my 62, and regret it every day.
I have NO problem with whichever scoop..... but please graft it onto a glass hood.
Are you happy with the quality of the aar hood ?Sorry - I don't think it will help you as it's an aftermarket AAR fiberglass hood so it's all molded with the 6-pack scoop.
I like your hood and stripe. I was just giving you some info you may not have knownMine is the correct scoop for a 1972 Dart. What other people are doing is no concern of mine. I'm just showing you a example of a 1972
I am 100% correct on my scoop. Maybe it's just a bad angle. It is not a 2 piece original. It's a single piece aftermarket. I have 40 hours making this piece perfect. Be aware this is how they come.I usually never give a disagree to anyone . But what comes around goes around.
Very much! But it was on the car when I bought it as a roller. From the history of the car, I know it is at least 15-18 yrs old, maybe more.Are you happy with the quality of the aar hood ?
After market is not the correct scoop for a 72. They would be correct for anything you bolt it on. I thought you were stating it was a 72 scoop. Its not even a factory mopar scoop. I didn't know that. I just saw the front was relieved for a 73 and you stated 72. Its a one scoop fits all. Sorry for not realizing it was after market.Mine is the correct scoop for a 1972 Dart. What other people are doing is no concern of mine. I'm just showing you a example of a 1972
It doesn't seem to be a common scoop. Even searching on YouTube and Google only turned up one car with itNobody put a picture of the tall dual that the OP purchased
Was it A purple Duster?It doesn't seem to be a common scoop. Even searching on YouTube and Google only turned up one car with it
No it was a blue swinger on YouTube. . .is that your duster? Have any more pics ?Was it A purple Duster?
Those are the hood graphics I'd like to do with my scoop
I believe I red a thread on this forum saying proper placement of the scoop is 3 1/4" from the back of the hood. Looks like I actually bought either 70/71 hood, are the corner bolt holes im using circled in black or red?
View attachment 1715836953View attachment 1715836954 View attachment 1715836955
