Whiplash Cam
rick360
- Mopar Or No Car -
chester,ct
I was considering putting a Whiplash Cam from Hughes Engines in my bored .030 over 318 I have, would it be overkill with stock heads? They have quite a bit of lift and not much duration to keep those cylinder pressures up. Probably make some good torque with it. What do you think? I'm going to do some mild porting to the heads too.
