When I first start the car it instantly goes to 50+lbs COLD, blurp the throttle it will hit 90+lbs, now this is cold. HOT it idles at around 32 lbs and will hit 65 lbs +
1) Are you running a windage tray??
2) Did you clearance your pickup before you put it on?
3) Are you running a high volume pump??
If you are running a HV pump, you could be sucking ALL the oil out of the pan because the capacity is not enough to feed it. Couple that with a BIG GAP from the pickup to the bottom of the pan and that could be a problem....
I run a windage tray always with a stock pan and use a stock pump and pickup. I do this even with a HP stroker build.........doing one right now with stock pan, pickup with windage tray on the 402 I have been working on.
