@SGBARRACUDA Roy, ain't you run a bunch of power through an 8 3/4?
Everything I know in life has been a lie!the semi float 60 is lighter than a 9" by 35lbs
Yup! Amount of power/torque vs weight/mass being moved coupled with the shock load, manual or automatic.I have been doing this a long time = My vote is to put in the
Dana for sure. I used to break plenty of 8 3/4 stuff with 3400 Lbs
with a 4 Speed and 550 HP!!
Do you feel it would have held up measurably longer at a weight loss of 400 lbs.?
Possibly. How many have you broken, at what weight with how much torque?I doubt the 400lbs would really add that much longevity.
I'm happy with my 8.75. They are pretty strong.I blew the caps up on my 8.75 at the strip this fall after getting my car finished and tuned, so I got a complete new Yukon 3rd and am going to replace the broken caps with the billet ones as a spare. (found out about the caps after I bought the new 3rd)
We set my car at 750whp this summer because of running out of injectors/pump, but it made 779 with maxing the injector duty cycle. I'm swapping injectors and pumps this winter to go back and break over 800 hopefully.
I have a dana 60 and all the stuff in a cart from Dr. Diff to build the 60 to swap into my car, was just curious before I do if anyone is running an 8.75 with with big power or if I should just do the 60. I also have someone lined up to buy the 8.75 for the $1600 I spent on the 3rd (nevermind the cost of chromo/green bearing shafts). Just sucks I'll have to have my driveshaft cut down for the 60 (its already 1350 joints) and I'll have to move my 4 link mounts on the chassis which is fine since I did all the fab myself, it just adds more to the to do list with a 60. Its a 70 Duster. Probably weighing around 3400lbs or so.
where is the thread at on this van ??????
Absolutely.400hp and 750hp are quiiittteee a bit different, even with a bit more weight.
Yeaaaaa, just a bit I’d say.400hp and 750hp are quiiittteee a bit different, even with a bit more weight.
I found my post where I measured the actual weights of a 8 3/4, came in at right around 200 lbs WITH brakes. I find it hard to believe that a 9 inch housing and an 8 3/4 housing weigh all that much different. The 3rd member vs center section I can see a difference as the 9 inch is beefier and oval shaped vs round.Same thing just happened to me when I looked it up
What do you want to know? I will start a thread, look out for it.where is the thread at on this van ??????
We have a '77 Shorty and love it. It would be cool if you started a thread and showed more pictures, sharing more details
You are right, for you. I guess I come at it from a traction standpoint. With slicks, an 8 3/4 will last a while, but I wouldn't trust it, and I think I would replace it before I broke it. Heck, Mopar put a Dana behind a 375 horse 440, with a stick, and a 390 horse with a 727.@33IMP FWIW, I have no issues with mine at that power level in TQ & HP. 360 4spd 4.10 ‘73 Cuda, PS-PB car, 30 years now.
Dana weight varies greatly, depending on heavy duty truck axle tubes, or car tubes. I don't think the current crop of aftermarket race Dana's are all that much heavier than an 8 3/4 or nine.I found my post where I measured the actual weights of a 8 3/4, came in at right around 200 lbs WITH brakes. I find it hard to believe that a 9 inch housing and an 8 3/4 housing weigh all that much different. The 3rd member vs center section I can see a difference as the 9 inch is beefier and oval shaped vs round.
I would think the axle housing tubes of a 60 would weigh as much as the entire housing of a 9 or 8 3/4.
Not arguing just surprised
When the article mentions the "massively heavy nine inch dana" the article loses some credibility, and the bias (from a company that builds nines, almost exclusively) is readily apparent!Here's a good article about the Ford 9" compared to the Dana 60.
The 9-inch Ford Rearend is the Strongest Rearend Out There—It’s All Due to “Hypoid Distance”.
