DaveBonds
Garage Trash
wow the info thats here.....i started the thread and then i had to leave for awhile and come back to a lot of info lol.......this is great.
but to be a pain i have a two new questions:
1. i have seen people add a quart of trans fluid to the oil every other oil change and the logic is that the trans fluid has detergents that will actually clean out the engine of previous neglect ....and i have to admit i did this on my slant six in my dart when i first got the car ......when i got the the oil in it from the previous was kinda sludgy ...and the filter on it was ancient ......it was k-mart brand.....like how old is that........i did notice increased leaking after that ....so i replaced the oil pan and valve cover gaskets and been running now over a year and i have put around 12,000 miles with no other problems.
whats you take on trans fluid in the oil. is it a good idea.
2. would synthetic call for a different oil change interval than dino?
on newer cars i have been in the habit of letting it go 5000 for oil changes ....and usually i look at the oil and it really is pretty clean and the engines are in great shape.......would the dino really break down faster and not make 5000......assuming the engine is in good shape as i understand a worn engine will dirty any oil with blowby and in-efficiency.
1. - Transmission fluid is a modified oil, designed to act as a hydraulic fluid and as a wet clutch fluid. It has friction modifiers in it for the clutches. This is why people prefer to change their power steering hydraulic system to a more suitable hydraulic oil that does not have a friction modifier in it, like power steering fluid.
The friction modifiers actually aid in metal adhesion under friction pressures, so I could imagine that it would bind with contaminants and do what you are talking about.
There are better things on the market that are designed to clean engines, both on the oil and combustion side, to decarbon. I would suggest using those, instead of something that hasn't been lab tested with proven results. It may not hurt the engine when used as a changing detergent, but then again, that is guess work. The idea is based on it's viscosity and friction modifiers, but without seeing how it reacts to engine temp, I don't know what it does on a molecular level to the metal surfaces, so I wouldn't suggest it.
2. - Oil change interval is directly related to the application of engine and oil type. Synthetic oil is more stable in wear and viscosity properties between cold and hot temp. Oil viscosity is rated at cold and hot temps, cold in viscosity testing is @ 72°F, hot is @ 212°F... So when the engine oil temp is below 72°, the viscosity can increase drastically.
Your best friend;
http://www.bobistheoilguy.com
Bookmark it.
Oil running temps change with use. Heavy loads increase oil temp. The usage of it's additives and increase of carbon pollutants also increase with the temp.
How you drive the car or use the engine changes how often you should change your oil.
Newer engines, because of the higher requirements of thinner oils and tighter clearances, fuel injection and having more detergents, have fewer pollutants from those things. This means that the oil has fewer additives that are used up, during the usage cycle, as well as running cleaner within it's use cycle, so it can inherently have a longer use cycle.
These older engines still require a 3000 mile change (or less if you beat the snot out of your engine) because of the components needing those additives that are used up within that frame of use cycle that new engines are simply void of, that have been engineered out of.
I still prefer a 3000 mile change in cold weather on new engines, even with synthetics, because the oil molecules are put through more extreme temp inversion, which changes it's elasticity and uniformity.
