The threads broke. It was an American made one from 440 source. I banged the pan on the rolling jack when I backed it off the lift but there was no external damage to the pan. I managed to get the broken part out with an EZ out screw extractor without damage to the thread.So did threads break/strip on tube?
Glad ya found the issue!
Yes I did. No parts showed any wear at all. They have less than 250 miles on themCorrect. It is also the same for V8s. The pickup is designed to rest on the bottom of the pan.
Kent, did you closely inspect the female drive hex in the pump and the pump drive shaft as well?
I just ordered it. backorder, 2 weeksYou really don't need that fancy pan and pickup.
I 'm using the Mancini 6qt a-body oil pan power package on my 451.
It don't run out of oil at 7500 rpm. lol
It is not just you. I blew a head gasket of theirs as well within 200 miles. This pickup they tout for stroker motors as it has clearance for the stroker. However, the clearanced area is where it broke. Maybe I tightened it too much and cracked it then??Is it just me or do I read a lot of 440 Source stuff breaking or junk?
Yeah, they also had that big block water pump housing that the inlet hole on the bottom hose barb was so small you couldn't get two fingers in it. Cause some over heating issues. They have "supposedly" rectified that issue. I didn't think "ANY" of their stuff was made in the USA.Is it just me or do I read a lot of 440 Source stuff breaking or junk?
When I ever have a problem, the first thing I ask myself, "what did I just do?". go through everything. If your pressure were that low, I think you would of heard a tapping sound. I think it would be possible a bad ground or the gauge itself.Let's see: EFI, onboard computers, electronic sensors, electronic gauges.
See a pattern here?
Spin in one of these shorty mechanical pressure gauges and see what you got.
Betting it's bad electronics for it to drop to nothing out of nowhere. View attachment 1715949870
Look back at previous posts. His oil pump pickup broke off and was lying in the bottom of the pan.When I ever have a problem, the first thing I ask myself, "what did I just do?". go through everything. If your pressure were that low, I think you would of heard a tapping sound. I think it would be possible a bad ground or the gauge itself.
Someone just posted in another thread they would pay to or three times for parts made in USA. I would too, but it sure would slow my project time way down. lolI set all my pickups 1/4 inch off the bottom of the pan..
As long as people want cheap parts, their going to be made in China..
What annoys me, is that people ***** when the cheap part breaks..
I would of thought with a broken pickup, he would of had "0" pressure. A crack yes. He must of finished breaking it off for the photo.Look back at previous posts. His oil pump pickup broke off and was lying in the bottom of the pan.
Beats me.I would of thought with a broken pickup, he would of had "0" pressure. A crack yes. He must of finished breaking it off for the photo.
Seems to me a support bracket bolted to another main cap bolt would help support it against vibration. May need a main bolt with a small stud or main stud with extra length to put support bracket and nut on. Kind of like some use for windage tray installation.The threads broke. It was an American made one from 440 source. I banged the pan on the rolling jack when I backed it off the lift but there was no external damage to the pan. I managed to get the broken part out with an EZ out screw extractor without damage to the thread.
I just placed an order with Mancini for a new Mopar performance 6 qt pan and pickup. The volume is 1 quart less that what I have but I will not be racing autocross, just some test and tunes. 2 week back order Yet I will have almost 2 more inches of ground clearance.
I put a little Loctite on the threads to seal them position the pickup where I want it, let it dry overnight. Then I tack weld the pickup tube to the pump, never had any issues.Small block. I had a pickup tube that would not turn enough to fit the screen flat to the pan. The recommended choice was to use enough teflon tape to build a tight fit with it backed off. NO!!
I got a pipe die and screwed it on till it was finger tight and gave it 3/4's turn to retaper the threads a little. Screwed it back in to the oil pump and BANG, screen was level to pan and tight without any teflon tape.
I will make sure to prime but I will use the drill method as that is all I have. Going to be a couple weeks before the new pan and pickup arrive.I put a little Loctite on the threads to seal them position the pickup where I want it, let it dry overnight. Then I tack weld the pickup tube to the pump, never had any issues.
Note to the OP
I would prime that motor before you start it again after your repair.
I dont use the drill method myself, I use a pressure system and run 5 quarts of oil throught the engine rotate the crank and verify that all the rockers are receiving oil.
Good luck and keep posting
Jim K
Do not forget that the suction port on the oil pump may be real close or at the oil level in the pan. If that is the case it could suck a bit of oil off the surface, enough for a few pounds oil pressure.I would of thought with a broken pickup, he would of had "0" pressure. A crack yes. He must of finished breaking it off for the photo.
That's the setup I have worked out great been racing and street driving for 2 years.The threads broke. It was an American made one from 440 source. I banged the pan on the rolling jack when I backed it off the lift but there was no external damage to the pan. I managed to get the broken part out with an EZ out screw extractor without damage to the thread.
