@68original Because I have a Max Wedge and I can too! Then you add fenderwell headers! Nuthin' like the sweet sound of a 4 barrel carburetor exceptin' if you have TWO 4 barrel carburetors!
And two Thumper carbs to boot! That is wicked Man!
I don’t see how. Even more so with a pair of Cater style carbs.
Jet it, set it, forget it, you’re done.
@harrisonm , I have read several posts about six packs fitting under hoods on this forum.Hey, @coloradohill, did your hood close over that 6 Pack setup. I have seriously considered a 6 pack for my 69 340 Barracuda, but I don't want to install a scoop.
For me, it’s the look. Having multiple carbs can be a headache, but nothing looks cooler.
Easily? You couldn’t till holley came out with the 3 barrel carbs sometime around 67-68 ish.
Up until that time it was 750 cfm.
Good info and lots to drool over, thanks to all! I'm not smart enough to tune any carb much less multiples, but it's fun to think about.
Back in another lifetime, there was only 1 barrel carbs. So to get more airflow people built 2, 3, 4 and 6 carb manifolds.I was doing a little thinking-over-coffee this morning, and while perusing some threads where dual quads were a topic I came up with more questions than answers. In a nutshell, why would a person want to run dual quads instead of a single carb? For sure there is the coolness factor and visual appeal but otherwise what's the benefit? If running a pair of 600 CFM (or whatever size) carbs why not just run a big single 4-barrel?
Enquiring minds want to know...
Good reason to join a local car club and get to know people's expertise. Usually willing to help and explain what and why. You buy the pizza and beers.Good info and lots to drool over, thanks to all! I'm not smart enough to tune any carb much less multiples, but it's fun to think about.
Yes they did. By then the WCFB's were on the way out but still used on small blocks. The 409 would have had a pair of Carter AFB carbs. Probably 500CFM but possibly 625CFM carbs.1962 to 64 409 chev had dual fours,
