An a-body rearend is 57 1/8" drum to drum with a 43" spring pad width. Also an a-body rearend has equal length axles left and right so the pinion is offset to the right side of the car so it matches the engine being offset to the right. Most Ford rearends have unequal length axles so the pinion is centered in the car. This may or may not be of issue to you.
Chuck
According to one of the charts on this site the A-Body 8 3/4" is 51.4". (Same as the 8 1/4). The 57" dimension appears to be for the B bodies. I know that the B body rears have been put in the A bodies, but these already are wider then what came in the A's. If you go with the 57" and go wider I'm thinkin' there might be an issue.
