I wanted to know if a super six intake manifold would bolt right onto my plain ol' Jane 225 slant six without replacing my exhaust manifold or doing anything else major?
The short answer is yes. It will bolt right up, no problems.
The problems come when you put an aftermarket carb (holley, demon, weber, etc.) on it. Then you may/may not have to deal with accelerator rods/cables and kickdown cables.
But almost every combination has been done so if you give some specifics I am sure you will get a detailed answer.
You may also run into choke pocket issues depending on the year of the exhaust manifold. You can mount an electric choke on the carb and it will work just fine.
Frank
