will b - body headman headers fit 1971 scamp with 383 big block?
Yes. Go to big block .com and seek there tech articles. I used the headmen Eliete (sp?) headers in a '71 Duster with a B block 400. The write up & instructions are very good.
if you are running an auto then there shouldn't be any problems, but if you are running a 4 speed....the Z-bar is going to complicate everything and turn a beautiful thing into a PITA
Then go to a cable operated clutch. Bam. Problem solved.
Looks horrible? How you figure? Most clutch cables you cannot even see.
