gzig5
That's thinking out of the box. I like it. Should be able to balance that small amount of aluminum out.What if you bore that one cylinder .040 or 60 and use 1 oversized piston? They weigh the same out the box supposedly.
nice thinking out of the box like said…
…But that’s not cleaning up with .010 more bore.
I very doubt it will clean up with .060 (.030 more.
As a machinist, I'd like to point out that if they sleeve one cylinder, it is going to distort the cylinder beside it....just want to mention that, something to think about.
i'm about to try to knock the raised portions off the wall and see how corroded it is. i do see where it looks pitted abought .250" below the deck, i'm guessing it's been leaking a long time and rings always knocked it off lower in the bore.
about to the pull the other head too, crossing fingers they all look good.
Like this idea, hope you won't have to buy two complete sets of rings!What if you bore that one cylinder .040 or 60 and use 1 oversized piston? They weigh the same out the box supposedly.
GM built engines that way. Different bores and different diameter crank journals. the manuals mentioned that when I was working at a GM dealer back in the day.That's thinking out of the box. I like it. Should be able to balance that small amount of aluminum out.
Where are you located?one thought was getting some .040 over Mahle pistons and selling these H116CP pistons. But that gets me into a sleeve AND bore and hone on the block. At that point it might make more sense financially to use a different block.
Wait… so a piston has been sliding over that nasty spot down in the bore?
… so that’s all “inny” corrosion? Not “outty” ?
Dingle hone. LOLAs a machinist, I'd like to point out that if they sleeve one cylinder, it is going to distort the cylinder beside it....just want to mention that, something to think about.
almost all is outty corrosion. I scraped it with a soft metal that was cut clean. Then more scotchbrite. Looks better but still really bad. The worst part is up at the top. You can see the bad corrosion.
I'll get some hate, but I'd run it. It'll kinda clean itself up to a point.
btw, the used and abused 8553PT gasket thickness is right at .050" on the fire rings. I think if I use 8553PT again I might spray them with something to help seal. Don't want these ******* leaks again...
pistons must be close to zero deck to be pumping 185-190psi 4 years ago (that was cold too). magnum chamber, i'm guessing it's the Mopar Purple cam 268/272- .450/.455 lift.
No hate here, you are right. A ball hone if possible and let her rip. No it is not perfect, but should get a few more years out of it.
I would at the very least take that piston out, clean it up, and make sure the rings aren't stuck.
second, do these look like stock magnum heads with some gasket matching? the pushrod pinch is .828" at the widest part.
The valves and springs look stock or what?? I see where the pushrod holes in the heads were massaged some but a few were still rubbing.
also is this raised pyramid shape in the port floor stock??
