6pakattack
Anyone know of an aftermarket or even stock windage tray for my /6 build ?? And compatible with my Main Stud kit !
Good luck. I got one but you caint have it.
Crank scrapers are better
Like anything else, it depends on what you're doing.
Just playing,no road racing !!
Well, just as your friend and his Ford proved more power can be made without one in his case, there have been countless dyno runs that have proven otherwise in other applications. Fact is, oil has weight and resistance and anything you can do to keep both those down will cause power to go up. Obviously that did not happen in the case of your friend's Ford. I am sure exceptions can be found to every rule.
Our turbocharged slant 6 has a deepened oil pan (the sump was dropped 2.5 inches) and I'm hoping that having the oil level down away from the crank will reduce windage to the point that we won't need a windage tray.
But, that's pure speculation on my part....
........that's pure speculation on my part....
what is a windage tray for?
Not a windage tray but a crank scraperwhat is a windage tray for?
