Darin
Active Member
Hi,
I am having an issue with the window sweeps (new) on a 67 Dodge Dart.
The rubber from the window sweep grabs the glass when raising the window and pulls the sweep edge up resulting in the edge being up instead of down causing problems when you go to lower the window. I end up using a plastic putty knife and push the rubber edge down while lowering the window. I don't know if the sweep is too sticky, thick or long. Anyone run into this issue and if so how did you resolve?
Thanks,
Darin
Thanks,
Darin
