Window track and body trim nut help needed
rod7515
Red Lion PA
Id like to start putting the windows back into my 66 Dart. I have everything removed from inside the door. The questions I have to start with are do I install the door handles and linkage or the window regulators and tracks? Also do I need to put the window wiskers in place before the window is installed?
Also I hope to start putting some emblems and trim back onto the car ad was wondering what you use inside the nuts for im guessing a sealer? Originally they had a rubber type material inside the nut. Of course that dried up and fell out long ago so I will need to replace it.
Hoping to make some progress here in the next 2 weeks.
Thanks Rod
Thanks Rod
I did the whiskers first, then regulator,rods and wing vent. then installed the glass with the door seals, locks and latches being last. then aligned the front window to the convertible A pillar and header, then the rear quarter glass to the side glass . Mine was cobbled together to make power windows front and rear though so your process may vary a bit from mine. I ordered speed nuts that had the sealant on them for all my GT trim(and tail lights) that had a threaded stud.
That sealer is white rope caulking, AKA- "dumdum". This stops water from leaking through. Buy it at your local hardware store.
