guysgts
68 GTS - 340 / 727
Does any one know if a 68/69 Cuda Gasket is the same as a 68/69 Dart?
Gordon340 said:I bought one off Ebay and was not pleased with it. It is not original and has a plastic insert. The one I bought off of Ebay for about 200.00 (including trim-lock), I will sell for 100.00 plus shipping. I do not think you would be happy with it either, but will sell it to you if you want it.
Brian
I see, is a good idea! I believe than I found a shop where have the gaskets, I`ll buy a complete kit and compare with the original, I try too remove the glass without cut the gasket, but the gasket is very hard (older).Longgone said:Cuda67Spain- To remove the windshield without cutting the gasket you will need a thin piece of strong wire (like a guitar string). Pass the wire through the outer edge of the gasket from the outside and tie it to a strip of wood on the inside. Tie a piece of wood to the wire on the outside as well and have a friend hold tension on it. With you on the inside and your friend on the outside, alternate pulling the wire with a sawing motion around the perimeter of the windshield. When you`ve gone all the way around the windshield, gently push it from the inside out. Be patient and you`ll be able to remove the entire windshield/gasket assembly as one piece. Good luck!
nz68rt said:I have one of the non correct seals fitted to the rear screen of my 67 hardtop, it leaks and has big gaps between the seal and the frame - very ugly and has to go. So I think I am reading this right, the 68/69 seal and trim will fit the 67 ? and the same goes for the front screen ?
Is the screen the same for all 68 - 72 A body coupes or just the seals interchange ?
Thanks!!!! If anybody come to Spain, have a lot of beers from me!!!
