wiper motor question
72demon
Mishawaka IN
I recently installed my six pack went to install air cleaner and it hits the wiper motor do they make a shorter wiper motor ? I need about a inch and a half to be able to set the air cleaner I dont want to cut it they are pricy besides it is a original cleaner
I believe you might have room if you went to a three speed wiper motor...looks like you have the two speed right now. I'm not really sure what's involved in changing though.
Same problem on the Demon here. Detailed up the 2 spd wiper motor perfectly and dang thing is in the way. A 3 spd motor will fix your problem, but you will also need to get the 3 spd wiring harness & switch.
A small ball peen hammer at the right spot on the base of the air cleaner where it hits works pretty easy. :bootysha:
