I'm looking for people to measure the length of wire required to build Alternator Charge stud to Starter Relay Stud wire around set ups.
If you have any of these cars, I'd appreciate some assistance in getting the wire lengths. Using a piece of string or wire, mirror the same path the OEM wiring, following the valve cover , back to firewall, across firewall then up inner fender to starter relay.
63-66 A body /6
63-66 A body /6 w/AC
67-76 A body /6
67-76 A body /6 w/AC
67-76 A body SB w/AC 84" Thanks 318moparguy
If you are looking for a bulkhead wire around, I'll provide them at a discounted rate to the first responders to each length that assists completing the database.
Thanks for any help
Rob
63-66 A body /6
67-76 A body /6
Thanks for any help
Rob
