Thomas Dennis
Since the wiring harness in my Green 75 Duster is so hacked up I'm going to pull the one out of my parts car. Both cars were /6 factory A/C cars. However the Green car had a small block in it when I got it with a destroyed wiring harness. Since the parts car wiring has all the plugs and wires I'm going to just rebuild that one. I've started marking the wires as I remove them so I know where they will go. I realize that I will have to modify a few of the connectors and wires for the V8 engine. I've got a few connectors plugged into some electrical boxes/relays that I do not know what they are for or if they will be needed on a v8. Here some pictures of the boxes relays Is picture with the single wire the temp sensor? Thanks
