PatrioticMopar
Active Member
Ok my lovelies,
This should be the last time I bug you all before firing up and breaking in the 318.
I installed a new HEI distributor with an internal module. I have it wired up, but I know I need to run a wire from the positive side of the coil to 12v power.
My question is do I hook it to continuous run voltage (blue) or the start voltage (brown) thanks!!
