joes68340s
I recently purchased a 71 D100 that was converted from 6 to small block. I have noticed that at idle the balancer has a wobble. I checked for crank walk it seems good. When rotating the engine you can see it as it closes the gap with the timing marker almost touches then back to an 1/8 in gap. I have never seen this before. Could this be the balancer slip on the rubber ring.
