I didn't pull the plugs this time, but at the end of last season when I had this problem I pulled the plugs and they were dry.onehellofadart said:Mikel did you pull the plugs to see if they were wet with antifreeze or if you spit out any water when you crank it by hand?
My gut feeling is it's the starter.
69signetv8 - next time it's locked up I'll pull the plugs and see what happens. If that frees it up, what would that indicate?
