dustya_383
Hey guys so I just swapped my 410 4speed into my other 74 duster ( came out of a 74 duster). I swapped motor trans. Rearend and steering column. Steering column is for as stick car. Everything was working in. Other car msd everything Now car won't start from ignition. Only relay and when I do it from relay it wont fire . do I need to crank in the car while pressing pedal to get it fire cause me jumping it from relay just isn't working. But I can't do that till I figure out why it's not cranking from ignition. I grounded the neutral safety wire that goes down to auto trans. What am I doin wrong. I need to get this car moved by tomorrow thanks guys
