THE STEVE
"part-time wheelman"
hey gang, i got a 77 van 360 engine in my 72 duster. stock bottom end, stock pistons (dished). heads have been ported quite a bit with stock valves.
cam is an erson 4.88lift 292duration i think (been a few years since i built it)
intake is a victor single plane with a holley 650dp. and a proform HEI dist. 2400 stall, 8.25 rear with 3.55s
flowtech headers.
my question is: would it be worth it to tear the engine down (has less than 10k miles since built) and install flat top pistons? also maybe install larger intake and exhaust valves? i know both of these thing will help performance, but will it be worth the trouble? or should i just keep what i got and save for the 440. i got a 440 but that would require a whole drivetrain swap again, and i dont plan on having the money for that in a few years. i work at a machine shop and i can do the labor for free. my boss (cale kern speed shop) has given me his 2 cents i was just wanting a second opinion. id like to also swap 4.10s in soon.
flowtech headers.
