Would like to run AC with a six pack
340doc
Hollywood Fl
I'm considering installing a six pack and would like to keep my factory air on my 71 Duster. Small block with power steering. Don't mind changing to a smaller compressor. Any info out there? I'm sure its been done. Thanks
Thanks 6pack, you did a great job on the installation and documenting it. I'm going to call them and see if I can get the parts I need to replace just the compressor and get some lines made up. Thanks again!
Hey 340doc, Just to let you know, I needed 1 custom AC line made due to the compressor being turned 90* and it was only $25 from a local shop.
I believe the Sanden compressor is available from many vendors...
Thanks for the kudos on the install thread & hope yours go smoothly if that's what you decide :D
