Snake
Mopar Nut
86 360.In the first pic you can see the upper right coolant passage.When i put the gasket on the second pic that passage is block,if i flip the gasket the passage is open,but the dowes dont line up.Same thing with the outher gasket,and same thing on the left bank.What up this is the gasket i got.I would think she gona over heat with that passage block off.
