WTB 69-76 small block FEDERAL p/s pump pulley
MrCuda68
Florida
Rating - 0%
0   0   0
I am looking for a power steering pump pulley that fits the FEDERAL style pump used from 1969 thru 1976 on small blocks. This pump has a round reservoir and a round fill tube.The pump shaft has a threaded hole in the end and is 5/8" in diameter, with NO keyway. I believe this pump was used on all engines but the pulley and brackets would be different. Similar pumps were used on 67-68, however the shaft on those pumps is smaller in diameter (9/16" I believe) and does NOT have the threaded hole.
Thanks for any help you may have.
Thanks easyrider, anxiously awaiting your update.
Sorry MrCuda68, I've been out of town and have not had a chance to get down to the shop. This pulley came off a 65 Dart, so it may be the smaller shaft. Will be home tomorrow and will check.
Tom
That will be the next stop if I can't come up with an origional.
Pulley found, purchased, and received.
Thanks FABO
Thanks mopar373
