[Found!] WTB 904 Park Cable and Housing for Floor Shifter '65 Barracuda
JoePowers
'65 Barracuda, my daughter's high school ride
Texas Almighty
Hi, I need a good park cable housing and cable for my 1965 Barracuda 904 transmission. It's for a floor shifter. Thanks.
Do you need the shift cable, or park cable? Your picture shows the park cable. Also, do you have a column shifter or floor shifter? I'm pretty sure the cables are different.
Oh yes. I'm sorry. It's a park cable for a floor shifter. I'll change the listing. Thanks Charrlie!
Do you some measurements on it? Length of housing, and overall length? I have a few cables I can check....
What's wrong with yours? It doesn't look broken or damaged....
The cable got cut and trans fluid leaked out. Then I tried to remove cable from housing to replace cable. I carefully tried to remove the pin from the housing to release the cable and the housing cracked. I feel terrible I ruined this piece.
