WTB: Early 273-4 bbl throttle cable bracket
65Val
Average Length Member
Victoria, BC, Canada, EH!
Looking for an early 273-4bbl throttle bracket (see pic) for a friend. Needs to fit the stock, cast-iron 273 Commando intake.
Thanks, Gang!
I have 67 273 4 bbl parts car that probably has that. If you still need it i'll check.
Thanks anyway. One has been found. Besides, it needed to be from a '65, as in the pic. '67's are completely different.
Thought you made one???
It was actually for a friend, and , yes, he modified a 2 barrel one to fit his 4 barrel carb. Here's what he did.....
1st pic - original 2 bbl bracket, exploded view.
2nd pic - rebent 2bbl bracket to 4bbl configuration, exploded view
3rd pic - revamped bracket assembled
4th pic - new-fabbed bracket installed on engine.
