[SOLD] X block W5’s 355 ci
Mgc340
Sioux Falls, South Dakota
Mopar X block brand new
4.020 bore
JE pistons
Mopar 3.50 crank
Child’s & Alberts I beam rods
New piston rings and bearings
Fluid damper harmonic balancer
Water pump
59’ bushed lifters
The cam specs are 278/284 duration @ 0.050". Lobe lift is 0.407".
Used billet msd distributor
New W5 heads, springs and valves
Used W5 Intake needs to be milled to fit heads
Block is O-ringed
4 bolt mains
Sheet metal valve covers
This motor was built but Arrow race engine for ARCA racing and was never used! Best if the best..... motor is set up for dry sump oil but can be switched back to wet very easy. One motor mount on driver side needs was milled off for dry sump oil pump, motor plate needs to be used.
$6000 complete
Or $4000 for short block minus heads, intake, valve covers and distributor
