2nd Dart 67
Not sure if this is in the right section, I apologize if not. I have a 1967 Dart GT and recently bought a complete 340 that I'm building for it. I found the casting numbers for the heads, but the right is different from the left. They do have the same size valves, just not sure why the casting numbers are different unless one was replaced, as long as they will work together than great. Here are the numbers: 2531894 D :::: 3418915 B
From my research it seems that the 253... is originally to the '70 block, however it seems the 341... is a TA head.
Any thoughts or concerns?
Thank you!
Thank you!
