Cuda416
I've been looking at cams for my sons 5.9 magnum and saw the Xtreme Energy Computer Controlled line. What is different about these cams from a non computer controlled unit?
They're designed to work within the limitations of the factory PCM programming and fuel injection system, so it doesn't start throwing codes all the time.
Advertised Intake Duration | 258 |
Advertised Exhaust Duration | 264 |
Intake Duration at .050 Inch Lift | 206 |
Exhaust Duration at .050 Inch Lift | 212 |
Intake Valve Lift | 0.480 |
Exhaust Valve Lift | 0.480 |
Lobe Separation | 112 |
My 2002 Van was a one ton. Got 12 MPG hwy. Could hall any load but I could have out run in if I had on good footwear. Got rid of it still running fine little smoke on startup at 600,000 miles. Needed another trans. I guess I should have pulled the 360 out when I gave it away. A good friend was going to use it with new trans. But junked it. Bet the motor needed everythingAnd since the Magnums never came in anything but trucks (okay, vans too), they're generally designed to enhance bottom end torque (not necessarily a terrible thing) and not higher rpm HP.
