37fleetwood
- Joined
- Jan 19, 2009
- Messages
- 391
- Reaction score
- 26
Ok, there is an advantage growing up being the kid of the guy with 50 Mopars in his back yard!
I have been reading all the rear end swap threads and decided to go out and check a few things out for myself. I went over to my Dad's and made some measurements and here are the preliminary results.
8 3/4" A-body flange to flange approx. 52"
7 1/4" A-body flange to flange approx. 53"
we've heard this before right? how about this:
1962-64 8 3/4" B-body flange to flange approx. 53" (1965 B-body may be the same without the tapered axles)
I plan on bringing one over and seeing how hard it would be to change it over to the newer slip on drum axles and brakes. if it can be done using all OEM parts I'll make a list of the parts used.
Heck, I may even consider using the tapered axles if I have to, it sure would be an easy swap!
