I am replacing my timing cover with an aluminum one from AR Engineering, That means that I will also change the oil pan gasket as well. My question is, has anyone used the reusable gaskets from Mancini for the oil pan? How did they work? Also, I have a windage tray so that means 2 gaskets. Am I asking too much if I try to use 2 reusable gaskets for this job?
I also consider doing a normal gasket to hold the windage tray and the reusable one to hold the pan.
