Aspen Racer
yesIs that the engine for sale in the "Interior parts for sale" forum?
I agree with that. It depends on what you are going to use the engine for and compression ratio, and horsepower goals, my point was before putting out a ton of money for machine work I would have the bores sonic tested its cheap insurance. My engine was for strictly drag racing so for me it was an easy decision. Yours could be different. The cost for an R3 block is very expensive I get that.When strokers started happening on mass that was a worry but has proven not to be a big deal.
Agree. Racers can be stubborn.It's not my duty to make sure the car goes the number...that's on the racer. If the car sucks, or is sub par...not my problem. I can't hold everyone's hand. I do offer advice to our customers, again maybe they follow it...maybe they don't.
Converters seem to be the biggest problem with cars not running good #'s with a known HP engine. See this way too much! A buddy of mine running a Ford had me do his heads and intake, car slowed down...I kept telling him to check rpm at trap...never would. But I somehow got the blame for it slowing down...until he changed engines (more power) and it went even slower! That's when he wised up and changed converter/trans and car came to life...it is what it is.
I’m going to try 6800 rpm sometime so I can say I did it.
If it's the same guy I'm thinking of, loose bearing clearances are worth hp, and reversing stock pistons must be worth 10-15 even though it won't show on the dyno. I wonder if it works even better on aftermarket pistons?I don't like to name names.. but it's the same guy that thinks bearing clearance is an abstract idea so there is no reason to actually check it.
I think you know this but I’ll say for those that don’t.If it's the same guy I'm thinking of, loose bearing clearances are worth hp, and reversing stock pistons must be worth 10-15 even though it won't show on the dyno. I wonder if it works even better on aftermarket pistons?
Welcome aboard Isaac.I Know a guy that ran a 408 stroker like 10 years without refreshing it. Just oil changes every year . The Engine was build by Dennis Maurer in Tempe Arizona . It was running on a 68 Barracuda , Super Street Car.
Mopar crankshaft , block bored with deck plates, Edelbrock heads, compression was like 10.5-11:1 . The Engine was running and it had a problem with the water pump motor and overheated , thats how it died .
