Your Preferred Engine Coolant Temp “Part 1”
Part 1: What engine coolant temperature do you strive for?
  • 160° Street
    Votes: 0 0.0%
  • 160° Street/Strip
    Votes: 1 4.2%
  • 160° Race
    Votes: 0 0.0%
  • 170° Street
    Votes: 3 12.5%
  • 170° Street/Strip
    Votes: 3 12.5%
  • 170° Race
    Votes: 0 0.0%
  • 180° Street
    Votes: 9 37.5%
  • 180° Street/Strip
    Votes: 8 33.3%
  • 180° Race
    Votes: 0 0.0%
  • Less than 160° (All)
    Votes: 0 0.0%
  • Total voters
    24
12many
SC
Everyone loves a cooling discussion right? :rolleyes:
Instead of a discussion, How about a poll about coolant temps?
What engine coolant temperature do you run at. Doesn’t matter if it is the actual temp your engine runs at, being the best you can do with what you have, if you can run that temp, or if you are working towards that # while driving/making a run.
Street, Street/Strip, Race
Only one pick total (no voting in both polls please) for your main car, or the one you are most concerned about regarding coolant temps.
Round down or up if somewhere in the middle.
Hopefully your picking based on where it runs best.
Would you change the pole to allow votes to be seen. Don't care who voted for want buy unless I vote in pole , #1 I can't see the results
A better question would have been: What coolant temp does your engine like?
There was a large thread a while back on what engine temp produces the most HP, your comment is spot on, each engine combo will be different in terms of best temp for HP
My pick is not on the list to choose.
I choose 185-210 degrees Fahrenheit, because it is normal.
