Z Bar attachment pins?
idrift
earth
Does anyone have a picture of the pins that attach the Z bar to the
pedal linkage and the clutch fork linkage for a 70 small block. Mine seems
kind of hacked together. I bought a new rod for the for from Brewers but
the pin on the Z bar is only about 5/16" diameter.
does this help ?
Not sure this will help you but found this pic I had. I made my own Zbar and used 1/2 stainless Bolts with nylon lockers. Hope this helps D
Thanks guys. My bar is um weird. Looks like I will also be doing some fabricating
on mine.
Thanks again!
M.H. I did get a kit from Brewers for everything but they hacked and welded
things up so the kit does not fit with the Z bar. I'll do some fabrication to try
to restore it close to original.
