Z BAR FRAME BRACKET LOCATION? photos?
wolfhammer
Wondering if anyone has a couple of photos of the weld location for a 69 A body z bar frame bracket. I have converted B bodies before but this is the first A body conversion for me. Is the frame rail marked or dimpled for it? Thanks for any help
It goes inside the wheel well with the wider part at the bottom. I can't locate a pic of mine.
It's welded in a few places,one is through the lower hole and a few on the sides and one on the outer top. The upper hole lines up with the hole in the inner fender
Here's a few shots of the one on my Demon. It's a factory 4 speed car so it should be in the correct location. I hope these help.
Ted
