PanGasket
has cork sides
thank you, its good to be bak. Good to see youNice to see you back
Sadly, no.:cry:. I am thinking whenever I get some spare cash for a master cylinder, I might do the brakes. Just cuz I can. Imma also see if I can get a 5/16" pipe bender so I can run the hardline to my carbdisgust. I keep bending the stupid things up and pinching em.](*,) I need some opinions on if I should just redo all the brake lines too. Someone said they are prone to rustin away though they looked okay to me when I was under it. My metal fuel lines were good, I replaced the rubber parts though. Replace the brakelines or will they be okay for now?? I also have to buy new bleeders just to be sure I can bleed the brakes when they are done.Any recent progress?
the last bend between the A/C compressor the front of the carb is weird. its difficult to get it to bend that tightly. I am just gonna borrow one from a friend just so I dont have to waste cash on pinching anymore. :tongue7:If you need to make minor bends in your metal fuel line just use a piece of pipe to curve the fuel line around, that will keep it from pinching, it works just like a pipe bender if you use the right size pipe..
You've just gone pro as they say.:toothy10:Probably a good idea if it's tight angles, I've never owned a bender, I've bent so many I can do it with my hands, damn bro I'm gettin' old...
thats a problem too. It took me forever to get my gas tank up because I had no one that wanted to help at the time:angry7:I have used sockets before. but tough with just 2 hands, holding socket and pipe.
Till I bought a bender for like $5. cheap but works fine.
Good help is hard to find, just wait until your laying on your back trying to put a transmission in by yourself, fun--fun..
I have a floor "trolley". The small style floor jacks. I definately need to upgrade as some point but it does its job damn well for now for $35 in a set with jackstands. lolAhh yes!! Been there a few times.Laying under a car with a tranny on your chest is fun! I'd bench press iut up with my arms and then get the tailshaft up with my legs/feet. Try not to drop it on your head!
Im always on my own putting stuff under cars. It's an unpleasant job most folks dont like,so a floor jack is your best friend.At least it wont flake out on you.
Thank you! That will help a lot! I have an orange box so I plan on using that because its what I gothttp://www.mymopar.com/downloads/elecignconv.pdf
You mentioned switching to electronic ignition so this might be helpful. It is much more up to date than my set dated 1981. You can use any year electronic ignition distributor but I suggest a 4 pin ecu and matching 2 pin ballast resistor.
Was supposed to, but I got sick of waitin after 6 months.Dang Mike, I thought you got the buckets long ago. But I'm glad you got some now get to work.......
I am all good dude. Thanks for the offer though! 8) I only needed one, the other one I had was bent all to hell. How you been? I haven't heard from you in a while. I still need to go and pick up that 904 and crossmember from middle GA. Damn gas pricesdisgust I need a lot of stuff from down there. Also need to visit Bruce while Im down there just to pay him a long overdue visit.:glasses7:mike i still have those headlight buckets from a 70 dart and you can get them in jefferson ga PM me if u still want them
which shop do you work at? and I will. I completely forgot you had them, but for now I am okay, thanks though:cheers:i've been doing pretty good been workin at a restoration/speed shop spend most of my time there. if you change your mind on the buckets just let me know
