moper
Question for the ‘65 gurus... what’s the correct route of the steel fuel line from the pump to carb? I have the stamped steel alternator bracket setup with a small clip on the bolt for the lower slide. Does the steel line run in front of the bracket, through the clip, then up and over the water pump and timing cover? Pics might help me...lol
