10” Drum Spring Configuration
340inabbody
Arizona
looks like some spring kits have changed the spring configuration from stock? Looks like there used to be 2 identical yellow return springs per brake but now the kits come with 1 yellow and one shorter black spring. See both photos. The shorter spring must also go into a different place on the shoe.
Question does it matter if the smaller spring is on the forward or rear right or left) position?
Looks like 11" uses equal sized return springs.
10 " uses different size.
10"
