72 duster back glass install
72dustervs
Winchester, Kentucky
I have seen some decent videos on installing the front windshield , but on the back glass not so much , would you recommend using butyl in the gasket and put on frame and then install glass , or no butyl ,,or would you use the rope method no butyl in gasket until after install ?
If the gasket is still live, I use the rope without any sealer. I like to lube it up with liquid soap or gritless GoJo. Makes washing things off easier.
Have you checked the FSM? They usually have procedures in them for reinstalling glass. I know the windshield installation procedure calls for sealant on the bottom half. Not sure about the rear glass though.
I will check that
