TRANSMISSION FIXTURE
CFD244
"I LOST MY ID IN A FLOOD"
Northern Ontario, Canada
Figured it was time to make my life easier. The numbers matching 727 is next in line for the H1 Demon restoration.
I've never thought about it until now, but I wonder if the tabs on the transmission that you used for the fixture attaching points are in the same place on both big and small block 727's? I would think that they would be since the cases between the 2 are the same, aft of the bellhousing.
Great job on the fixture! :thumbsup:
The tabs near the tail housing are the same, but at the bellhousing, the small block tabs are wider by about 2 inches. The dimension front to rear is the same between the two.
I use to use a 30 gallon drum. Put the tail shaft in and was able to remove and replace the drums. I was at a friends shop yesterday he was doing the same thing. Put the tranny on the table to adjust bands and valve body. I never used a fixture. Maybe I am old school:) Working on cars 50 plus years.
