Installing Exhaust Headers Into 300hp Crate Engine - Mopar Muscle Magazine
Dyno-Test 360 Smog Motor - Mopar Muscle Magazine
Chrysler 318 Engine - Popular Hot Rodding Magazine
318 Small Block Build - How To - Hot Rod Magazine
https://www.hotrod.com/articles/mopp-0312-318-long-block-bolt-ons/#:~:text=Our 318 now produced 282 hp at 5,000,hp by an intake, carb, and cam change.
318 Engine Buildup & Dyno Test - Mopar Muscle Magazine
Testing the Mopar 273 Power Pak on the Dyno
https://www.hotrod.com/articles/mopp-0102-1970-340-high-performance-mill-dyno/
How Bad Did Mopar’s 340 beat Ford & Chevy? Shocking New Data!
408-Inch Mopar Stroker-- Car Craft Magazine
Camshaft Comparison Testing
Make Big Power With Your Magnum 5.9L Mopar With These Heads!
How to Pick Budget Friendly Cylinder Heads for your 360 LA and Magnum Mopar Build
5.9L Magnum Engine - Make Mine A 5.9
https://www.hotrod.com/articles/build-500hp-capable-360-magnum-short-block-cheap/
Build Your Own 455HP Pump-Gas Magnum V8 For Around $4,000!
https://www.hotrod.com/articles/0901phr-mopar-318-magnum-engine/
https://www.hotrod.com/articles/hrdp-0804-small-block-mopar-engine/
https://www.hotrod.com/articles/mopp-0303-360-crate-engine-buildup/amp/
https://www.hotrod.com/articles/ccrp-1006-small-block-mopar-stroker-dyno-test/
https://www.hotrod.com/articles/mopp-0007-chrysler-360-engine/
https://www.hotrod.com/articles/la-...eanthem&utm_campaign=&utm_medium=&utm_source=
https://www.hotrod.com/articles/mopp-0706-front-suspension-engine-cradle/
https://www.hotrod.com/articles/0607phr-camshaft-basics/
