Magazine Builds
273
Ontario
Installing Exhaust Headers Into 300hp Crate Engine - Mopar Muscle Magazine
Dyno-Test 360 Smog Motor - Mopar Muscle Magazine
Chrysler 318 Engine - Popular Hot Rodding Magazine
318 Small Block Build - How To - Hot Rod Magazine
https://www.hotrod.com/articles/mopp-0312-318-long-block-bolt-ons/#:~:text=Our 318 now produced 282 hp at 5,000,hp by an intake, carb, and cam change.
318 Engine Buildup & Dyno Test - Mopar Muscle Magazine
Testing the Mopar 273 Power Pak on the Dyno
https://www.hotrod.com/articles/mopp-0102-1970-340-high-performance-mill-dyno/
How Bad Did Mopar’s 340 beat Ford & Chevy? Shocking New Data!
408-Inch Mopar Stroker-- Car Craft Magazine
Camshaft Comparison Testing
Make Big Power With Your Magnum 5.9L Mopar With These Heads!
How to Pick Budget Friendly Cylinder Heads for your 360 LA and Magnum Mopar Build
5.9L Magnum Engine - Make Mine A 5.9
https://www.hotrod.com/articles/build-500hp-capable-360-magnum-short-block-cheap/
Build Your Own 455HP Pump-Gas Magnum V8 For Around $4,000!
https://www.hotrod.com/articles/0901phr-mopar-318-magnum-engine/
https://www.hotrod.com/articles/hrdp-0804-small-block-mopar-engine/
https://www.hotrod.com/articles/mopp-0303-360-crate-engine-buildup/amp/
https://www.hotrod.com/articles/ccrp-1006-small-block-mopar-stroker-dyno-test/
https://www.hotrod.com/articles/mopp-0007-chrysler-360-engine/
https://www.hotrod.com/articles/la-...eanthem&utm_campaign=&utm_medium=&utm_source=
https://www.hotrod.com/articles/mopp-0706-front-suspension-engine-cradle/
https://www.hotrod.com/articles/0607phr-camshaft-basics/
My favourite that actually makes it to the track for some real world numbers if magazines are to be believed.
I get it but the idea of dyno isn't necessarily be real world, but able to compare mods from one another. most of these are done by the same dyno place and same people so there comparable to each other. So if most think of they want magazine 400 hp or whatever but you feel that's real-world 350 hp does really matter?
Some people actually race their junk. I take my junk to the track to get an ET slip to see what any change has actually improved or degraded my performance. Anything else is speculation and conjecture.
Build A 500HP Capable 360 Magnum Short-Block On The Cheap!
Iron-Headed Mopar 318 Magnum Engine- Popular Hot Rodding Magazine
How to Add 129hp to a 5.9l Mopar Magnum - Engine Buldup - Hot Rod Magazine
Small-Block Mopar Stroker Dyno Test - Car Craft Magazine
Good info. I'll make it a sticky!
I have a huge giant beef with how HR lays out their web pages. They are difficult to follow and impossible to somehow preserve if you actually want to reference something in them
Just another example of some would be software engineer who has no damn idea
change gives them job security just like forum software
m software
thanks for all the links has to be some good info in there , just have to find it
Not if the car isn't right. I've seen plenty of sure thang power mods and motor swaps get lost in tire smoke. **** ain't that straight forward unfortunately.
