Rat Patrol
At Mo Cars suggestion...Ive started a list of track results for Gen 3 retro fits
ILL accept ANY early body Mopars, rods or Brand X bodies with Gen 3 drivetrains
Post your stats in the format below...and Ill add it to the 'list'
Any data missing...it wont make the list...but the post will stay.
MODS - could you keep an eye on this and sticky if it starts to look promising?
USER- CAR - MOTOR - INDCTN - TRANS - GEARS - WEIGHT - STATS - TRK
eeka440 - 73 Swinger - 5.7 88mm turbo - powerglide - 8 3/4 - 2950# - 8.93 @ 149mph - Toronto Motorsports Park
boltone - 67 Cuda Fastback - 5.7 .020 over, 904 auto w/ 6300 stall, 5.14 gear, 3350# - 9.99 @ 130mph
RockinRobin - 70 Duster - 5.7/414, 4BBL, auto, 4.56 gears, 2850lbs, 10.10 @ 137mph - Various Tracks, Texas
408 Swinger, 1974 Swinger, 6.1 based 426, Ritter single plane(drag pak), 727 ATI convertor4500-5000, 4.10 dana, 3342 w/driver, best e.t.(good air) 10.23@130, Thunder Valley Dragways Marion S.D. elev 1351ft.
HemiJoejr - 68 Barracuda - 5.7, dual quads, auto, 4.56 gear, 3670lbs, 11.11 @ 120mph - Atco Raceway, NJ
ghinmi - 1983 Jeep Cherokee - 5.7 w/vvt locked - Bullseye billet S366 on 7 psi - TR6060 - 3.64 - 3995 lbs - 11.14 @ 125.5 - US131 Motorsports Park
mo-cars - 77 Valiant Ute - 6.1, 904, 4700 stall, 4.10 gears, 3505lbs w/ driver, 11.658 @ 113.96 - Willowbank Raceway Brisbane Australia
Rat Patrol - Aussie Charger - 6.1, dual quads,auto, 3.91, 3650lbs - 11.7 @115.4, 3650lbs, 4.11s, 1.71 60 ft, 6.1 with dual AVS and 2" spacers - Calder Park, Melb, Australia
Mcat - 68 Barracuda - 5.7, EFI, auto, 3.55 gears, NO WEIGHT, 12.08 @ 112mph - Edgewater, Ohio.
72BBSwinger - Dart - 6.1/420, EFI, Stick, 3.91 gears, ~3670lbs - 12.09 @ 121mph - GPS
Buschi340 - 72 Dart Swinger - 6.1, holley 750 DP, 5 Speed Toyota Supra , 4.10, ~3600 lbs - 12.718 @ 176.47kph ( 109.65 mph), 1.857sec 60ft, Drachten, Netherlands ( september 2016 ) on MT Slicks with 16psi
JoeBoy - 67 dart, 5.7 hemi with comp 268 cam, EFI, 200r4 with 2800 stall lock-up. 3420# with me. 12.99 @ 104 here in Denver at Bandimere.
cu440da- 78 Warlock- Stock 5.7L VVT- Active Intake EFI- Manual- 3.91- Actual weight with 2/3 tank of gas = 3880lbs - 13.49 @ 100mph- Rock Falls, WI
Map63Vette - (Car ??) - headers, ModMan, and SRT Max Plus cam running on MS2 Extra ECU with MSD ignition control - 3500# with me & 1/2 fuel - 13.61 @ 104
Ralphie361 - 69 Dart Swinger - 5.7, EFI, Stick, 3.23 gears, 2900 lbs, 14.19 @ 100.7 mph - Kilkare, Dayton, Ohio
